Topic: Black chalk
    »» Black chalk
Author Black chalk
cuesportkid
posticon   Posted: 2009-09-23 19:54
seriously not well cd. black red blue what difference does it make as long as it sticks to your tip
  Member Information For cuesportkidProfile   Send Private Message To cuesportkid   Quote And Reply To This MessageQuote
cd
brazil    avatar
posticon   Posted: 2009-09-23 22:18
Wow used some red chalk tonight and the amount of top left English U can apply is unreal
simmo77
posticon   Posted: 2009-09-23 23:04
Is there a time and place for a multi coloured chalk?
posticon   Posted: 2009-09-24 00:02
I heard that if you manage to the get chalk from the heart of the white cliffs of dover it does miracles for your game
cd
brazil    avatar
posticon   Posted: 2009-09-24 04:29
Thanks ads I shall look into it
posticon   Posted: 2009-09-24 07:58
no worries mate, dont mind sharing some of my secrets with you guys
cd
brazil    avatar
posticon   Posted: 2009-10-01 13:50
Here u go hotwheels. !!!
Darkside
dominica    avatar
posticon   Posted: 2009-10-01 16:49
Dixon....lmao
Darkside........geezas
  Member Information For DarksideProfile   Send Private Message To Darkside   Quote And Reply To This MessageQuote
TheSurgeon
posticon   Posted: 2009-10-01 21:50
The colouring is just a dye pal, there's no difference in the base compound used across a particular manufacturer's range (triangle, master etc).
For example - Blue Master will play different from Blue Triangle cos they're different ranges whereas Blue Master & Red Master will play exactly the same.
cd
brazil    avatar
posticon   Posted: 2009-10-02 06:57
your wrong widlo,
when i screw with black chalk i can get that muce gear on it i nearly scorch the cloth BUT when play with top i hardly get anything on it ???
BUT red chalk i get loads top on but cant play with screw
InsideEnglish
posticon   Posted: 2009-10-02 11:57
last time i screwed with black chalk, i got a nasty little rash....................... :-o
[ This message was edited by: InsideEnglish on 2009-10-02 11:57 ]
posticon   Posted: 2009-10-02 12:36
On 2009-10-02 06:57 , cd Wrote:
your wrong widlo,
Spend time on red chalk and black chalk?
Take two chalks into the pool room?
Not me!
I just want to chalk, and go!
So I use Tweeten Sassoon "Chalk & Go"...
Red chalk and black chalk in one cube!
Tweeten Sassoon "Chalk & Go" leaves my tip clean, fully conditioned, and looking terrific!
Use red chalk and black chalk? Not me, now I just "Chalk & Go"!!!
[ This message was edited by: BigDave on 2009-10-02 12:38 ]
    »» Black chalk
Page took 0.686208 seconds to load.
